Cynthia's test impressions make technical sense, what might be expected just from material knowledge. : "The regular sterling will often go quite dark or even black while the AS will only yellow or brown at most." I believe your "testing" results are uncontrolled and results out of context in some fashion.
As I stated in an earlier post, the I gave was
incorrect. It had been some time since I had worked in anything other
than Argentium Sterling Silver (I love the alloy). I remembered doing
the test, nearly a year ago, with the results as I had posted. Later
I remembered that that particular test was with fine silver…apples
and oranges. The statement that “The regular sterling will often go
most.” is correct. I apologize for giving incorrect
Marty Andersen
