The isolation transformer just "floats" the 240VAC away from GND. This means there is no longer a connection- as there is with the line fed voltage. This does nothing to protect you from getting zapped by the 240VAC
As stated the isolation transformer “floats” the mains and “breaks”
any ground link. Touching a “live” mains wire will not cause a shock
unless there is some connection to ground or to the “neutral” or
other related phase. I have seen films of workers safely working on
cables energised at 100’s of thousands of volts because they were
isolated from ground. They were actually bonded to the high voltage
cables that they were working on for safety!
The reason that I specified contact to EITHER side of the winding is
safe is that if you get hooked across it (ie both sides of the
winding) then the transformer will just see you as another appliance
and happily fry you. I have a few 240 volt isolation transformers
(Australian mains is 240 volts) and I can assure you that they do
work as I stated to protect you against mains connection. I have on
more than one occasion inadvertently touched a “live” trace when
using an isolation transformer without receiving a shock. The old
rule for electrical testing of live circuits was to keep one hand in
your pocket to prevent touching BOTH sides of the mains or ground.
An isolation transformer works well exactly as stated if it is in
good condition. It is also essential that there is no ground
connection to the output winding - I have seen units that have had a
bond fitted for some reason. If you are going to use one for
isolation purposes then I would recommend getting an electrician to
insulation test (megger test) it to ensure no leakage to earth on
either side of the output before trusting your life to it.
The GFI - Ground Fault Interrupter, is also called Safety Switch,
RCD - Residual Current Device, ELCB -Earth Leakage Circuit Breaker,
Core Balance Relay and other names in different places.
Before these devices were readily available, the isolation
transformer was the only protective device available. It is still
widely used to work (repair) on circuits that have mains potential
circuitry or to isolate test equipment earths to prevent short
circuits when testing such circuitry.
I am an electrician and I fitted all of my power and light circuits
in my house with individual safety switch protection so I don’t
discount the effectiveness of that mode of protection. It is another
line of protection to me in case of an isolation transformer failing
but that hasn’t ever happened.
It is also important that only a single appliance is plugged into a
isolation transformer at any time. Although the chance is remote,
if two items had faults to opposite sides of the output winding (eg
to the case of each) and you touched both cases, then you would be
effectively connected across the full potential. In Australia,
isolation transformers with output sockets are supposed to have a
surround (often a pvc pipe fitting) to ensure that only a plug is
inserted and prevent double adaptors etc being used for that reason.
As a last point, you were to use a standard “non isolating” variac
with GFI protection and contact something earthed (say when
anodising), it is possible to trip the GFI.
Regards,
Brian.
