Hello Fellow List Members:
I have been in the gem and jewelry industry for over 20 years
doing trade shows and the biggest problem that we have all come across is
proper display lighting. Well after 10 long months of working with several
lighting engineers I have come up with the solution and it is called SoLux
Daylight Lighting.
SoLux is the patented , revolutionary new display lighting to solve your
lighting requirements at the trade shows, in your office, store or your
home. This low voltage <12 volts, 50 watt>, MR-16 lamp produces 4700K
color temperature with no UV or IR. You can have up to 35
lamps/fixtures on a standard 15 amp power strip!
These lamps need a true 12 volts to produce to proper color temperature
and foot candles. We have found that no one makes a low voltage track
fixture that produces 12 volts under load until now. We now produce our
own “True 12 Volt” Track Fixture.
We also have a very professional adjustable Track Support System that puts
the lights out over your show cases so you can use this track lighting at
the shows.
SoLux Lamps come in four beam spreads: 10, 17, 24 and 36 degrees.
Pricing is $14.95 each, with quantity discounts.
For more go to http://www.gemdata.com SoLux lamps and True 12
Volt fixtures are in stock and ready to ship.
Thank you,
Lance Kanaby
GemData, Mine Design & The Spectrum Network at http://www.gemdata.com
Home
of the original interactive “Gem, Mineral & Jewelry Show Calendar” Colored
Gemstones, Diamonds & Cutting Rough Databases and Information SoLux
Daylight Lighting, email Lance Kanaby: mailto:@Lance_Kanaby
