Hi there was a miss print my name is jen I think they show it right
in a few other places I need almost everything, probably be easier to
tell you what I do have but here we go. hard to think what I need the
most. guess that would have to be hammers, I do not have even one,
and drawplates mostly use round, half round and square. I have 1 ring
mandrel, could use bracelet and bezel mandrels or bezel blocks. a
friend showed up the other day with some wood so I am in the middle
of building a jewelers bench, that will work with my wheel chair. so
I guess any bench accessories of ever sort I don’t even have a bench
pin. Dapping tools and blocks, I don’t even have die stamps As you
can see from my list I learned the old fashion way, so ingot moulds
and a old mill, stakes rounded or flat any type. I have no lapidary
tools at all. Mostly I do cabbing so a stone grinder and slabbing,
tumbler and grinding compounds. also could use some old books I never
learned casting something I regret but then my uncle never knew how
either. well That list should have you head spinning I know it has
mine going and I did not even put down a propane regulator for my old
torch the o2 is working fine but there is some rust on the inside of
the propane one most likely from Wilma. I had cleaned everything and
lubed everything up my old files only got a bit of rust cleaned up
nice. but could use a few more. well there is more like material to
work with but at this point you have the idea. I have a nice buffer,
a old barrel type dremel, my grinder just bit the dust and my friends
pitched in together and got me a new one so I could keep making
tools. have 8 file 2 saws, a propane torch and tank with no regulator
and acetylene torch with one tank, 1 o2 tank with a good regulator
could use a y, nice big set of chasing and repousse tools not not
even one hammer to use them. a drill and was just given a circular
saw to build my bench. a dozen small jewelers pliers 2 for cutting.
some uncut stones. and a shattered spine, a lot of hope, drive, and
determination not to give up, other then that I don’t have a clue
what to tell you. now for my tools glad to sell or trade
they are all custom order for most part I do sets of 10, or
individual mixed set of 10 are $80 individual tool price are based on
type and size
liner thin, liner thick, planishing, modeling, range from $5 to $8
each,
matting, jig, range from $8 to $26
i can make almost anything
just tell me what size type and shape you want. the sizes to pick
from are
1/4" x 1/8", 1/4" x 5/16", 1/4" x 1/4", 1/4" x 3/8", 1/4" x 1/2",
1/4" x
5/8",
now pick you type of tools
liner thin, liner thick, planishing, matting, jig, modeling,
now pick your shapes or shapes
square, round, half round, tear drop, oval, rectangular, straight
line,
curved, v shaped, diamond, triangle, trapezoid,
did i forget one tell me if i can make it, you can have it
